hs-up-load
Use the hs-up-load command from the hotspot context to configure the hotspot WLAN metrics Uplink load.
hs-up-load (0-255)
Parameters
(0-255) Specifies the hotspot WLAN metrics Uplink load.
EWC.extremenetworks.com:wlans:hs:hotspot# hs-up-load 255
