hs-venue-group
Use the hs-venue-group command from the hotspot context to configure the hotspot venue group information.
hs-venue-group (Unspecified|Assembly|Business|Educational|FactoryIndustrial|Institutional|Mercantile|Residential|Storage|UtilityMisc|Vehicular|Outdoor)
Parameters
(Unspecified|Assembly|Business|Educational|FactoryIndustrial|Institutional|Mercantile|Residential|Storage|UtilityMisc|Vehicular|Outdoor) Specifies the hotspot venue group.
Usage
You have the option to specify a venue type value after you specify a venue group value. For more information, see hs-venue-type.
EWC.extremenetworks.com:wlans:hs:hotspot# hs-venue-group Assembly
