Use the password command to specify the MAC authentication password to be used with the RADIUS server being configured. The password command is accessible from within the RADIUS server configuration mode from the wlans:<WLAN-service-name>:auth context of the CLI.
After you run the password command, run the apply command to implement the changes.
| password | Specify the MAC authentication password |
You must be in RADIUS server configuration mode for the password command to be available. Use the config command to enter RADIUS server configuration mode. For more information, see config.
The following example sets the MAC authentication password to techdoc:
EWC.extremenetworks.com:wlans:cnl-AAA:auth# password techdoc EWC.extremenetworks.com:wlans:cnl-AAA:auth# apply
Print
this page
Email this topic
Feedback
