Use the show routes command to display the routing table or static routes of the Wireless Appliance.
| all | Displays the routing table. |
| static | Displays the static routes. |
EWC.extremenetworks.com# show routes all Dest Addr Netmask Gateway Interface RouteType Status 0.0.0.0 0.0.0.0 10.7.0.2 esa0 Static Active 10.7.0.0 255.255.255.0 None esa0 Connected Active 10.7.1.0 255.255.255.0 None esa1 Connected Active 127.0.0.0 255.0.0.0 None lo Kernel Inactive 127.0.0.0 255.0.0.0 None lo Connected Active 136.157.233.128 255.255.255.128 192.168.1.1 eth0 Kernel Active 172.16.113.0 255.255.255.0 None esa2 Connected Active 172.16.114.0 255.255.255.0 None esa3 Connected Active 172.16.117.0 255.255.255.128 None esa5 Connected Active 172.16.117.128 255.255.255.128 None esa6 Connected Active 172.16.118.0 255.255.255.192 None esa7 Connected Active 172.16.118.64 255.255.255.192 None esa8 Connected Active 172.16.118.128 255.255.255.192 None esa9 Connected Active 172.16.118.192 255.255.255.192 None esa4 Connected Active 172.16.125.0 255.255.255.0 None esa10 Connected Active
The following example displays the static routes on the Wireless Appliance:
EWC.extremenetworks.com# show routes static RouteID Dest Addr Netmask Next Hop Interface OverrideDynamic 1 0.0.0.0 0.0.0.0 10.7.0.2 1 on
