Use the vsa-topology command to include topology information in the message to the RADIUS server. The vsa-topology command is accessible from the wlan:<WLAN-service-name>:auth context of the CLI.
After you run the vsa-topology command, run the apply command to implement the changes.
| enable | disable | Specifies to enable or disable the inclusion of Topology information in messages to the RADIUS server. |
The vsa-topology command is not available when the authentication mode is guestportal. When the authentication mode is disabled, MAC must be enabled for this command to be available. For more information, see mode.
The following example enables the inclusion of Topology information in messages to the RADIUS server:
EWC.extremenetworks.com:wlans:test:auth# vsa-topology enable EWC.extremenetworks.com:wlans:test:auth# apply EWC.extremenetworks.com:wlans:test:auth# show vsa-topology Topology as VSA attribute: enable
 Print
                        this page
Print
                        this page Email this topic
Email this topic Feedback
Feedback View PDF
View PDF Download EPUB
Download EPUB
