This section lists technical specifications for the hardware products described in this document.
Switch Model | Interfaces |
4220-12T-4X |
4220-12P-4X |
4220-24T-4X |
4220-24P-4X |
4220-48T-4X |
4220-48P-4X |
4220-4MW-8P-4X |
4220-4MW-20P-4X |
4220-8MW-40P-4X |
4220-8X |
Part Number | Weight | Physical Dimensions |
4220-12T-4X | 5.5 lb / 2.52 kg | 12.0 in W / 1.7 in H / 10.3 in
D 305 mm / 44 mm / 261 mm |
4220-12P-4X | 6.8 lb / 3.11 kg | |
4220-24T-4X | 7.0 lb / 3.16 kg | 17.36 in W / 1.7 in H / 10.0 in D 441 mm / 44 mm / 254 mm |
4220-24P-4X | 9.6 lb / 4.37 kg | 17.4 in W / 1.7 in H
/ 13.0 in D 441 mm / 44 mm / 330 mm |
4220-48T-4X | 10.0 lb / 4.53 kg | |
4220-48P-4X | 11.2 lb / 5.09 kg | |
4220-4MW-8P-4X | 7.1 lb / 3.23 kg | 12.0 in W / 1.7 in H / 10.3 in D 305 mm / 44 mm / 261 mm |
4220-4MW-20P-4X | 10.6 lb / 4.83 kg | 17.4 in W / 1.7 in H / 13.0 in
4220-8MW-40P-4X | 11.9 lb / 5.41 kg | |
4220-8X | 5.2 lb / 2.37 kg | 12.0 in W / 1.7 in H / 10.3 in D 305 mm / 44 mm / 261 mm |
RPS-550 | 5.0 lb / 2.26 kg | 12.6 in W / 1.7 in H
/ 7.9 in D 320 mm / 43.5 mm / 200 mm |
RPS-950 | 5.4 lb / 2.43 kg |
RPS-CBL-1M | 1.3 lb / 0.6 kg | 39.4 in W / 0.9 in H / 3.1 in D 1000 mm / 24 mm / 80 mm |
RPS-CBL-1M-2x7 | 1.0 lb / 0.5 kg | 39.4 in W / 0.9 in H / 2.4 in D 1000 mm / 23 mm / 62 mm |
