Example: Basic Stack with Four Switches
This example shows a stack of four switches in a single rack.
The slot numbers presume a console connection to the switch at the top of the physical stack.
SummitStack Cable Connections Using Four Switches with Integrated SummitStack Ports shows cable connections for a 4-node stack using SummitStack 40G cables to connect switches with integrated SummitStack ports.
Basic Stack with Four Switches: Connections lists the recommended order for connecting the stacking ports in this example.
Table 1. Basic Stack with Four Switches: Connections
Connect this slot and port . . .. . . To this slot and port
Slot 1
Stack Port 2
Slot 2
Stack Port 1
Slot 2
Stack Port 2
Slot 3
Stack Port 1
Slot 3
Stack Port 2
Slot 4
Stack Port 1
Slot 4
Stack Port 2
Slot 1
Stack Port 1
