To determine the size of UPS that you need:
  1. Locate the voltage and amperage requirements for each piece of equipment.
    These numbers are usually found on a sticker on the back or bottom of your equipment.
  2. Multiply the numbers together to get Volt-Amperes (VA):
    VA = Volts x Amperes
  3. Add the VA from all the pieces of equipment together to find the total VA requirement.
To determine the minimum volt-amperage requirements for your UPS, add 30% to the total.
