External Redundant Power Supply LEDs
The Power LED is located on the rear panel of the RPS. The following table presents the LED status and recommended actions if the LED is off.
ColorStatusRecommended Action
GreenAC input to RPS is within specifications.None.
OffAC input power to RPS is out of specification.
  1. Check AC power cord connection to the RPS.
  2. Check AC power at the power outlet.
  3. Swap power cord for a known good one.
If the problem persists, contact Extreme Networks for support.
