Example: Stacked Switches across Several Racks
Top-of-Rack Stack Installation shows five switches installed at the tops of five adjacent racks. To accommodate the shortest possible cables, immediately adjacent switches are not always connected together. Port 2 on one switch is connected to Port 1 on the next connected switch. If the easy setup feature is used to configure the stack parameters, the assigned slot numbers will be as shown in the figure.
Stacked Switches across Several Racks: Connections lists the recommended order for connecting the stacking ports in this example.
Table 1. Stacked Switches across Several Racks: Connections
Connect this slot and port . . .. . . To this slot and port
Slot 1Rack APort 2Slot 2Rack BPort 1
Slot 2Rack BPort 2Slot 3Rack DPort 1
Slot 3Rack DPort 2Slot 4Rack EPort 1
Slot 4Rack EPort 2Slot 5Rack CPort 1
Slot 5Rack CPort 2Slot 1(Rack APort 1
