Build Basic Stacks
A stack can be created in either of two ways:
The 5120 Series supports native stacking in Native-V100 stacking mode beginning with Switch Engine 33.3. The 5120-44X-4Y-2C switch supports alternate stacking beginning with Switch Engine 33.4. See Combine Switches from Different Series for more information about cross-stacking 5120 Series switches with other switches.
When planning and building your stack, be sure to follow port compatibility and cabling recommendations as described in this chapter.
