Universal Ethernet Ports
The Universal Ethernet ports, or stacking ports, are located on the front panel of the switch and are labeled U1 and U2. These ports can be used with Switch Engine as stacking ports or as Ethernet ports.
The Universal Ethernet ports operate as Ethernet ports by default. Use the commands
configure stacking-support stack-ports all selection native V100
enable stacking-support
to set the U1 and U2 ports in stacking mode.
When used as Ethernet ports, the U1 and U2 ports support data rates of 25Gbs using SFP28 optics. 5120-44X-4Y-2C, 5120-44X-4Y-2C-AC-F, 5120-44X-4Y-2C-AC- R, 5120-44X-4Y-2C-TAA, and 5120-44X-4Y-2C-AC-F-TAA switches support data rates of 100Gbps on the QSFP28 ports 49 and 50.
For information on switch stacking, see Build Stacks.
