Replace a Fan Module
5120 Series switches support the following fans:
Remove a Fan Module
Use the following instructions to remove a fan module.
  1. Gently pull the tab (labeled Air Out or Air In) on the end of the fan module.
    The fan module is held in place by spring clips. As you pull, the clips disengage and the fan stops.
  2. Slide the fan module out of the switch and set it aside.
Install a Fan Module
Use the following instructions to install a fan module.
  1. Verify that the airflow direction on the replacement fan module matches that of the installed power supplies and any fan modules.
  2. Carefully slide the replacement fan module into the switch.
    Do not force the installation. If the fan assembly does not slide in easily, ensure that it is correctly oriented before continuing.
    Push until the fan module snaps into place. The fan automatically starts to operate.
