Power Specifications
Power Supply Options
XN-ACPWR-150W
XN-ACPWR-150W-FB
XN-ACPWR-600W
XN-ACPWR-600W-FB
XN-ACPWR-920W
XN-ACPWR-920W-FB-U
XN-ACPWR-1200W*
XN-ACPWR-1200W-FB
XN-ACPWR-2000W**
XN-ACPWR-2000-FB-A
Voltage Input
Range (Nominal)
100-127/200-240
VAC
100-127/200-240
VAC
100-127/200-240
VAC
100-127/200-240
VAC
100-127/200-240
VAC
Line Frequency Range47Hz to 63Hz47Hz to 63Hz47Hz to 63Hz47Hz to 63Hz47Hz to 63Hz
Power Supply Input SocketIEC/EN60320 C14IEC/EN60320 C14IEC/EN60320 C14IEC/EN60320 C16
IEC/EN 60320 C14 (for -FB)
IEC/EN60320 C16
IEC/EN 60320 C14 (for -FB-A)
Power Cord Input PlugIEC/EN60320 C13IEC/EN60320 C13IEC/EN60320 C13IEC/EN60320 C15
IEC/EN 60320 C13 (for -FB)
IEC/EN60320 C15
IEC/EN 60320 C13 (for -FB-A)
Operating Temperature
0°C to 50°C (32°F to 122°F)
Normal Operation
Normal Operation
Normal Operation
Normal Operation
0°C to 45°C
(32°F to 113°F)***
5420F Internal Fixed and Secondary Power Supply Options
ModelInternal Fixed Power Supply Unit (PSU)*Secondary Power Supply Unit (PSU)**
5420F-24T-4XE120W AC PSUXN-ACPWR-150W or
XN-ACPWR-150W-FB
5420F-24P-4XE660W AC PSUXN-ACPWR-600W or
XN-ACPWR-600W-FB
5420F-24S-4XE150W AC PSUXN-ACPWR-150W or
XN-ACPWR-150W-FB
5420F-48T-4XE120W AC PSUXN-ACPWR-150W or
XN-ACPWR-150W-FB
5420F-48P-4XE860W AC PSUXN-ACPWR-920W or
XN-ACPWR-1200W-FB
5420F-48P-4XL860W AC PSUXN-ACPWR-920W or
XN-ACPWR-1200W-FB
5420F-8W-16P-4XE660W AC PSUXN-ACPWR-600W or
XN-ACPWR-600W-FB
5420F-16W-32P-4XE1200W AC PSUXN-ACPWR-1200W or
XN-ACPWR-1200W-FB
5420F-16MW-32P-4XE1200W AC PSUXN-ACPWR-1200W or
XN-ACPWR-1200W-FB
5420F PoE Power Budget
ModelPoE Budget with Single Internal Fixed PSUPoE Budget with Recommended Secondary PSU
5420F-24P-4XE380W720W
5420F-48P-4XE740W1440W
5420F-48P-4XL740W1440W
5420F-8W-16P-4XE480W960W
5420F-16W-32P-4XE872W*/960W**1437W*/1874W**
5420F-16MW-32P-4XE860W*/960W**1425W*/1862W**
5420M Primary and Secondary Power Supply Options
ModelPrimary Power Supply Unit (PSU)*Secondary Power Supply Unit (PSU)*
5420M-24W-24S-4YEXN-ACPWR-920W-FB-U or
XN-ACPWR-1200W-FB
XN-ACPWR-1200W-FB
5420M-24T-4YEXN-ACPWR-150W or
XN-ACPWR-150W-FB
XN-ACPWR-150W or
XN-ACPWR-150W-FB
5420M-24W-4YE
XN-ACPWR-1200W-FB
XN-ACPWR-1200W-FB
5420M-48T-4YEXN-ACPWR-150W or
XN-ACPWR-150W-FB
XN-ACPWR-150W or
XN-ACPWR-150W-FB
5420M-48W-4YEXN-ACPWR-920W,
XN-ACPWR-2000W,
XN-ACPWR-1200W-FB, or XN-ACPWR-2000W-FB-A
XN-ACPWR-920W,
XN-ACPWR-2000W, or
XN-ACPWR-1200W-FB,
XN-ACPWR-2000W-FB-A
5420M-16MW-32P-4YEXN-ACPWR-920W,
XN-ACPWR-2000W,
XN-ACPWR-920W,
XN-ACPWR-2000W, or
XN-ACPWR-1200W-FB,
XN-ACPWR-2000W-FB-A
5420M PoE Power Budget
ModelPower SupplyPoE Budget with Single Primary PSUPoE Budget with Optional Secondary PSU
5420M-24W-24S-4YE
XN-ACPWR-1200W-FB
720W1440W
5420M-24W-4YE
XN-ACPWR-1200W-FB
720W1440W
XN-ACPWR-1200W-FB
804W1558W
XN-ACPWR-2000W
XN-ACPWR-2000W-FB-A
884W*/1440W**1704W*/2880W**
XN-ACPWR-1200W-FB
787W1541W
XN-ACPWR-2000W
XN-ACPWR-2000W-FB-A
884W*/1440W**1687W*/2400W**
Minimum/Maximum Power Consumption and Heat Dissipation
Table 1. 5420F Switches
Switch ModelMinimum Power Consumption (W)Minimum Heat Dissipation (BTU/hr)Maximum Power Consumption (W)*Maximum Heat Dissipation (BTU/hr)**
5420F-24T-4XE248162211
5420F-24P-4XE37127833387
5420F-24S-4XE35119114388
5420F-48T-4XE3110675255
5420F-48P-4XE481641674663
5420F-48P-4XL491681657604
5420F-8W-16P-4XE371271092452
5420F-16W-32P-4XE461562150785
5420F-16MW-32P-4XE501722152790
Table 2. 5420M Switches
5420M-24W-24S-4YE45.51551632656
5420M-24T-4YE289557194
5420M-24W-4YE431481601551
5420M-48T-4YE3411768232
5420M-48W-4YE722453090716
5420M-16MW-32P-4YE692342564560
