Install Your Switch
Before you attempt to install or remove an Extreme Networks switch, read the precautions in Safety Considerations for Installation.
If you are installing switches for use in a stacking configuration, read Build Stacks before you install the switches.
Extreme Networks switches fit into standard 19-inch equipment racks.
The provided rack-mounting brackets attach to the front of the switch and are adaptable to either a front-mount or mid-mount installation. Optional rear-mounting brackets are also included for four-post racks or cabinets
The installation process includes the following tasks:
Table 1. Switch Installation Tasks
StepProcedureDescription
1What You Will Need for the Installation Prepare to install the switch
2 Attach the Switch to a Rack or Cabinet Install the switch in the rack.
4Install Optional Components Install optional components: optical transceivers and cables.
5Install Internal Power Supplies Install one or two power supplies in 5420M switches, or install one optional power supply in 5420F switches.
6Connect the Switches to Form the Stack Ring Connect stacking cables for a stacked configuration.
7Connect Network Interface Cables Connect network interface cables.
8Turn on the Switch Power up the switch.
9Activate and Verify the Switch Perform initial network connection and configuration.
