5420 Series Installation Guide
> Monitor the Switch
Extreme Networks, Inc. July 01, 2026
Introduction to the 5420 Series Installation Guide
New in this Guide
5420 Series Overview
5420F-8W-16P-4XE Switch Features
5420F-24P-4XE Switch Features
5420F-24S-4XE Switch Features
5420F-24T-4XE Switch Features
5420F-16MW-32P-4XE Switch Features
5420F-16W-32P-4XE Switch Features
5420F-48P-4XE Switch Features
5420F-48P-4XL Switch Features
5420F-48T-4XE Switch Features
5420M-24T-4YE Switch Features
5420M-24W-4YE Switch Features
5420M-24W-24S-4YE Switch Features
5420M-16MW-32P-4YE Switch Features
5420M-48T-4YE Switch Features
5420M-48W-4YE Switch Features
Secure Boot
Manage Your Switch
Universal Ethernet Ports
Fan Modules for Use with Your Switch
Fan Modules
Power Supplies for Use with Your Switch
150 W AC Power Supply
600 W AC PoE Power Supply
920 W AC PoE Power Supply
1200 W AC PoE Power Supply
2000 W AC PoE Power Supply
Minimum Software Version for Power Supplies on 5420 Series Switches
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Requirements for PoE Devices
Power Supply Requirements
Power Cord Requirements
Select a UPS
Build Stacks
Introduction to Stacking
Build Basic Stacks
Slot Numbers in Stacks
SummitStack Topologies
SummitStack Terms
Plan to Create Your Stack
Enable and Disable the Stacking Support Option
Recommendations for Placing Switches for Stacked Operation
Recommendations for Configuring Stacks
Combine Switches from Different Series
Select Stacking Cables
Use the Extreme Stacking Tool
Set up the Physical Stack
Connect the Switches to Form the Stack Ring
Examples of Valid Stacking Configurations
Example: Basic Stack with Four Switches
Example: Basic Stack with Eight Switches
Example: Stacked Switches across Several Racks
Connect Your Stack to the Management Network
Install Your Switch
Install Optional Components
Install Internal Power Supplies
Turn on the Switch
Log In for the First Time on Switch Engine
Change the Switch OS via the Bootloader Menu
Change the Switch OS via the Startup Menu
Log In for the First Time on Fabric Engine
Remove and Replace Components
Remove a Switch from a Rack
Remove a Switch from a Two-Post Rack
Replace Power Supplies
Power Supply Airflow Direction Requirements
Replace a Power Supply
Replace Fan Modules
Fan Airflow Direction Requirements
Replace a Fan Module
Monitor the Switch
System Status LEDs
Monitor Inlet Air Temperature
Technical Specifications
5420 Series Technical Specifications
Acoustic Noise and Fan Speed
CPU, Memory Specifications
Mean Time Between Failures
Power Specifications
Environmental
Standards
EMI/EMC Standards
Console Connector Pinouts
General Safety Precautions
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
EMC Warnings
Japan (VCCI Class A)
Korea EMC Statement
Monitor the Switch
The following topics help you monitor the status of the switch as it is running.
Section contents:
System Status LEDs
