| Model | 7520-48Y-8C 7520-48YE-8CE | 7520-48XT-6C |
| Ports |
| Power Supplies |
| Fan Modules |
| Dimensions |
| Weight |
| Performance |
| CPU/Memory |
| Packet Buffers | 32MB | 32MB |
| Environmental Operating Conditions |
AC/DC, one fan failed, front-to-back:
AC/DC, one fan failed, back-to-front:
| Model | Weight | Physical Dimensions |
XN-FAN-001-F: Fan unit, front-to-back or XN-FAN-001-R: Fan Unit back-to-front | 0.14 kg (0.31 lb) | Height: 4.0 cm (1.57 in) Width: 4.0 cm (1.57 in) Length: 13.4 cm (5.28 in) |
XN-4P-RKMT298 - Four-post rack mount kit (included with 7520-48Y-8C and 7520-48XT-6C switches) | 2.63 kg (5.8 lb) | Height: 2.1 cm (0.83 in) Width: 4.4 cm (1.73 in) Length: 63.0 cm - 90.0 cm (24.80 in - 35.43 in) |
XN-4P-RKMT302 - Four-post rack mount kit (included with 7520-48YE-8CE switch) | 2.84 kg (6.26 lb) | Height: 5.0 cm (1.97 in) Width: 7.0 cm (2.76 in) Length: 72.0 cm (28.4 in) |
XN-2P-RKMT299 - Two-post rack mount kit (separately orderable) | 2.8 kg (6.17 lb) | Height: 4.44 cm (1.75 in) Width: 2.0 cm (0.79 in) Length: 67.93 cm - 93.24 cm (26.76 in - 36.73 in) |
| Description | |
| XN-RJ45-DB9-CONSOLE-CBL | RJ45 to DB9 Console cable (6ft) |
| XN-RJ45-USBA-CONSOLE-CBL | RJ45 to USBA Console cable (6ft)* |
| XN-RJ45-USBC-CONSOLE-CBL | RJ45 to USBC Console cable (6ft)* |
* The cable might require an FTDI software driver on some operating systems.
