Install Your Switch
Before you attempt to install or remove an Extreme Networks switch, read the precautions in Safety Considerations for Installation.
If you are installing switches for use in a stacking configuration, read Build Stacks before you install the switches.
Extreme Networks switches fit into standard 19-inch equipment racks.
A four-post rack-mounting kit is provided with the switch. A two-post kit can be ordered separately.
The installation process includes the following tasks:
Table 1. Switch Installation Tasks
StepProcedureDescription
1What You Will Need for the Installation Prepare to install the switch
2 Attach the Switch to a Rack or Cabinet Attach the Switch to a Rack or a Cabinet Install the switch in the rack.
3Install Expansion Modules Install expansion modules, if the switch supports expansion modules.
4Install Optional Components Install optional components: optical transceivers and cables.
5Install Internal Power Supplies
6Connect the Switches to Form the Stack Ring Connect stacking cables for a stacked configuration, if the switch supports stacking.
7Connect Network Interface Cables Connect network interface cables.
8Turn on the Switch Power up the switch.
9Activate and Verify the Switch Perform initial network connection and configuration.
