Build Basic Stacks
A stack can be created in either of two ways:
The Extreme 7520 supports native stacking in Native-V400 stacking mode. The switch also supports Native-V400 Alternative Configuration stacking mode. The Extreme 7520 does not support alternate stacking. See Combine Switches from Different Series for more information about cross-stacking Extreme 7520 switches with other switches.
When planning and building your stack, be sure to follow port compatibility and cabling recommendations as described in this chapter.
