When your stack is operational, one switch is the primary switch, responsible for running network protocols and managing the stack.
To provide recovery in case of a break in the stack connections, you can configure redundancy by designating a backup switch to take over as primary if the primary switch fails. When you perform the initial software configuration of the stack, the “easy setup” configuration option automatically configures redundancy, with slot 1 as the primary and slot 2 as the backup. You can also configure additional switches as “primary-capable,” meaning they can become a stack primary in case the initial backup switch fails.
Extreme 7520 switches can be stacked with themselves or with Extreme 7720 switches using the SummitStack V400 stacking method or the SummitStack-V400 Alternative Configuration method. One switch is as capable as the other.
The 7520-48YE-8CE switches do not support stacking.
