The management console is a PC or terminal terminal-emulation software that is connected to the serial console port on the switch (an RJ45 jack) by a serial or console cable. The management console is used to monitor and configure the switch locally, using terminal emulator software such as HyperTerminal on a PC, or TERM, Tip, or Kermit in a LINUX environment.
Use the following instructions to connect the switch to a management console.
Flow control is not supported on the serial consoles when attached to remote terminal servers and must be disabled to ensure proper operation.tip /dev/ttyb -115200
If ttyb is already in use, use ttya instead and enter the following string at the prompt:
tip /dev/ttya -115200
