External Interfaces contains external interfaces and weights and dimensions information for Extreme 8730 switches.
| Interfaces | Description |
| Ports |
| Power Supplies |
| Fan Tray |
| Dimensions |
| Weight |
| Accessory | Weight | Dimensions |
| XN-FAN-006-FB: Fan, front-to-back XN-FAN-006-BF: Fan, back-to-front |
0.18kg (0.39lb) | 42.0mm W x 40.9mm H x 136.7mm D (1.65 in W x 1.61 in H x 5.38in D) |
| XN-ACPWR-1600W-FB-A: PSU, front-to-back XN-ACPWR-1600W-BF-A: PSU, back-to-front | 2.69lb (1.22kg) | 54.5mm W x 40.2mm H x 352mm D (2.15in W x 1.58in H x 13.86in D) |
| XN-DCPWR-1600W-FB-A: PSU, front-to-back XN-DCPWR-1600W-FB-A: PSU, front-to-back | 2.77lb (1.26kg) | 54.5mm W x 40.2mm H x 352mm D (2.15in W x 1.58in H x 13.86in D) |
XN-4P-RKMT302 - Four-post rack mount kit (included with switch) |
2.84kg (6.26lb) | 70mm W x 50mm H x 720.0mm D (2.76in W x 1.97in H x 28.4in D) |
XN-2P-RMKIT-005 - Two-post rack mount kit (ordered separately) |
0.17kg (0.375lb) | 44.1mm W x 20.2mm H x 80.0mm D (1.74in W x 0.8in H x 3.15in D) |
| Description | |
| XN-RJ45-DB9-CONSOLE-CBL | RJ45 to DB9 Console cable (6ft) |
| XN-RJ45-USBA-CONSOLE-CBL | RJ45 to USBA Console cable (6ft)* |
| XN-RJ45-USBC-CONSOLE-CBL | RJ45 to USBC Console cable (6ft)* |
* The cable might require a FTDI software driver on some operating systems.
