FEC Configuration Support
Configure Forward Error Correction (FEC) on a port to obtain error control in data transmission over an unreliable or noisy channel. You can configure FEC on 400 Gbps ports, 100 Gbps ports, and 25 Gbps ports.
The following FEC options are supported:
FEC ModeHost Interface ConfigurationPeer Interface ConfigurationLink Operational StatusLINK FEC Operational StatusComments
Auto DetectAutoAutoUpn/aOperational FEC based on present transceiver
RS-FECn/an/aLink operational status and operational FEC based on present transceiver. If transceiver default have RS-FEC and peer configured as RS-FEC link will comes up and operational FEC is RS-FEC.
FC-FECn/an/a
Disablen/an/a
RS-FECRS-FECAutoDepends on present transceiverDepends on present transceivern/a
RS-FECUpRSFEC/RS528/RS544-2xNDepends on peer interface support
FC-FECDownDisablen/a
DisableDownDisablen/a
FC-FECFC-FECAutoDepends on present transceiverDepends on present transceivern/a
RS-FECDownDisable
FC-FECUpFC-FEC
DisableDownDisable
DisableDisableAutoDepends on present transceiverDepends on present transceivern/a
RS-FECDownDisable
FC-FECDownDisable
DisableUpDisable
Important
Important
On ports that support FEC configuration, ensure that you configure the same option at both end points. Otherwise, the link does not come up.
