Fan Modules
Two fan module options, with front-to-back or back-to-front airflow, are available for Extreme 8730 switch models:
Fan modules labeled Air In provide back-to-front airflow. Fan modules labeled Air Out provide front-to-back airflow.
Fan Airflow Directions
Fan modules are ordered separately for the base Extreme 8730 switch. Fans are included with other switches.
For information on installing or replacing a fan module, see Replace Fan Modules.
