8730 Series Installation Guide
> Monitor the Switch
Extreme Networks, Inc. October 01, 2026
Introduction to the Extreme 8730 Installation Guide
Extreme Support Portal
Create an End Customer Extreme Support Portal Account
Create a Partner Extreme Support Portal Account
New in this Guide
Extreme 8730 Overview
8730 Series Switch Features
Manage Your Switch
FEC Configuration Support
Fan Modules for Use with Your Switch
Fan Modules
Power Supplies for Use with Your Switch
1600 W AC Power Supplies
1600 W DC Power Supplies
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Install Optional Components
Install Internal Power Supplies
Turn on the Switch
Login for the First Time on Extreme OS ONE
Remove and Replace Components
Remove a Switch From a Rack
Remove a Switch from a Four-Post Rack
Remove a Switch from a Two-Post Rack
Replace Power Supplies
Power Supply Airflow Direction Requirements
Replace a Power Supply
Connect a DC Power Supply to the Source Voltage
Replace Fan Modules
Fan Airflow Direction Requirements
Replace a Fan Module
Monitor the Switch
System Status LEDs
1G/10G SFP+ Management Port LEDs
QSFP-DD Port and Sub-channel Selector LEDs
QSFP28 Port LEDs
Technical Specifications
Extreme 8730 Technical Specifications
Acoustic Noise and Fan Speed
CPU and Memory
Mean Time Between Failures
Power Specifications
Environmental
Standards
EMI/EMC Standards
Console Connector Pinouts
General Safety Precautions
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
EMC Warnings
Japan (VCCI Class A)
KCC statement (Republic of Korea)
Monitor the Switch
The following topics help you monitor the status of the switch as it is running.
Section contents:
System Status LEDs
QSFP28 Port LEDs
