Increase BMC Security This topic discusses the steps to increase BMC's security including changing the password for the default account, and changing the default IP address for the BMC's network interface.
Change BMC User Password BMC firmware ships with the well known default User ID of 2 with the password set to qct.admin. This information being well know, is a huge vulnerability and the best practice is to change the default password as early as possible.
Enable the BMC Management Interface By default, the BMC Management Interface is disabled in SLX-OS devices. It must be manually enabled and configured.
Configure BMC Management Interface IP Address BMC firmware ships with the well known default configuration of DHCP for the BMC Management Interface. Once SLX-OS firmware is downloaded and installed, SLX-OS configures it predefined static IP address to the BMC Management Interface.
Managing BMC Management Interface BMC firmware ships with the well known default configuration of DHCP for the BMC Management Interface. Once SLX-OS firmware is downloaded and installed, SLX-OS configures it predefined static IP address to the BMC Management Interface. SLX-OS configures the following static IP 192. 168.11.1/24 and default gateway 0.0.0.0 by default.
Reset BMC Configuration to Factory Defaults In case of a security breach, it might be required that the configuration applied to a BMC's be reset to the factory defaults. Use the bmc factory reset command to do so.
