The no deploy command brings down and removes the TPVM and associated disks from the current configuration. However, in some cases, the command might fail to remove the configured disks.
To completely remove TPVM and its associated disks, use the undeploy-force command. The command removes associated disks from the current configuration without fail. This command can also be used to forcibly remove any virtual disks that were retained when TPVM was uninstalled using the no deploy command.
Section contents:
