Follow these steps to enable ZTP in standalone mode.
Establish a network connection with cable on
one-to-multiple in-band ports or a management interface.
Power up the device in the factory default
configuration or run the write
erase command from the SLX-OS CLI.
On device boot up, the ZTP process performs the
following actions:
Disables the RASlog to the serial output.
Enables in-band ports in the management
VRF.
Detects a DHCP server with
option 66 or 67 or 43 configured over a management interface and all
in-band port interfaces.
Option 43 is used when the DHCP server supports HTTPS protocol.
Selects one interface not used before to
assign the DHCP IP address.
Downloads the ZTP
configuration file from the FTP/HTTP/HTTPS server depending on the
configured option.
Validates the ZTP configuration file.
If required, ZTP performs a firmware
download. Firmware download reboots the device automatically. If no
firmware download is needed, the ZTP process continues to configure the
switch.
In the current state the ZTP process
returns to substep (b) in the following situations:
- If there is a failure in any of the above-mentioned
substeps from (b) through (g)
- If the device reboots from the CLI
- If the device crashes
On device bootup, the continuation of the
ZTP process is indicated on the console. Wait for firmware commit to complete.
If the firmware commit fails, the ZTP process aborts. If the script is enabled,
the script is launched automatically.
Enable the RASlog.
For more information and log outputs for
canceling DHCP ZTP, refer to the SLX-OS Command
Reference Guide.
