Interface Ethernet ports All Extreme device ports are pre-configured with default values that allow the device to be fully operational at initial startup without any additional configuration. In some configuration scenarios, changes to the port parameters may be necessary to adjust to attached devices or other network requirements.
Interface reload delay to prevent traffic black-holing in vLAG The bring-up of edge interfaces before a vLAG is formed and before BGP routes converge results in traffic black-holing. The reload-delay feature addresses that problem by delaying the forming of Link Aggregation Control Protocol (LACP) on interfaces. The reload-delay command configures a global delay-time value for all interfaces on which reload delay is enabled but the delay is not specified.
System clock The operation of the device does not depend on the date and time and the Extreme device with an incorrect date and time value functions properly. However, since logging, error detection, and troubleshooting use the date and time, you should set the clock correctly.
Management VRFs Virtual Routing and Forwarding (VRF) is a technology that controls information flow within a network, isolating the traffic by partitioning the network into different logical VRF domains.
Heartbeat between SLX and EFA This topic discusses the need for a heartbeat between SLX and EFA and how the state of the SLX can be modified based on the heart beats received from EFA.
Zero Touch Provisioning Zero Touch Provisioning (ZTP) is an automated process that uses the DHCP process to download firmware and set up the device configuration.
TCAM application-resource monitoring Ternary Content Addressable Memory (TCAM) is specialized memory that stores complex tabular data and supports very rapid parallel lookups.
Hardware profiles A variety of hardware profiles optimize ASIC resources for counters, port-channels, routes, and Ternary Content-Addressable Memory (TCAM)-allocation.
Rebooting into Maintenance Mode The config-system-maintenance command provides two methods for you to access the maintenance mode. The first is to use the enable parameter, which puts the device into maintenance mode after a specified convergence time. The second method, uses the enable-on-reboot command, allowing the device to enter maintenance mode upon reboot. Use of this command does not disturb the current operation of the device.
