Install Engine Application
Install the Docker application image file on the appliance.
  1. Go to Engines > Installation.
  2. From the application pane for the intended application, select Install.
    • If you have not yet uploaded the application Docker image file, you will be prompted to do so.
    • The installation time will depend on a variety of factors, be prepared for it to take some time.
    A confirmation notice displays after the installation completes. Only one instance is required for the cluster.
