Connect to the Management Interface through the ICC1 Port
You can retain the default IP address of the appliance management interface if you do not connect the appliance to your enterprise network. If you connect the appliance to your network, follow these steps:
  1. Connect a laptop to the appliance management port.
  2. Configure the Ethernet port of the laptop with a statically assigned unused IP address in the 192.168.10.0/24 subnet.
  3. SSH to the appliance.
    192.168.10.1 is the default IP address on the appliance management port).
    The Universal Compute Platform logon screen is displayed.
  4. Using the console session, access the Basic Configuration Wizard.
