Validate the Network Address Configuration
Validate the IP addresses that you configured previously through the Configuration Wizard.
To access the network settings in the user interface:
  1. Go to Administration > System > Network Setup.
  2. Verify the host attributes.
    Network Setup - Host Attributes
  3. Select additional ports as necessary to display and verify the interface settings. If you make any changes to the additional interface settings, select Save.
Configuring an engine instance IP address for the admin interface of the container application is useful for diagnostic purposes. The web interface can be accessed from the Engine Settings.
