Use this optional procedure to configure a persistent connection to the ExtremeCloud network using the CloudOps Management setting. CloudOps uses this persistent connection to manage software delivery for the cluster.
By default, the setting is On for all Managed Orchestration clusters. By turning the setting to Off, you can limit software installs and upgrades to specific maintenance windows.
If CloudOps Management is Off, the setting can be turned back on by an administrator at the customer organization or by the CloudOps team (using remote GUI access).
