Before configuring the cluster, use your Extreme Support account to download the latest revision of Universal Compute Platform software from the Extreme Networks Support Portal.
The image file uses one of these extensions:
A best practice is to upgrade each of the nodes on a new cluster to the latest revision before proceeding with the cluster set up and configuration.
When all nodes in the cluster are upgraded to the latest revision, proceed to IP Address Configuration.
