ExtremeCloud Edge Planning
This guide outlines the steps required to prepare a cluster environment that will support deployment of ExtremeCloud Edge applications to the customers' premises.
Minimum Requirements for Installation
Application requirements for the cluster configuration:
Out-of-Bound Routing for Outgoing Traffic
The VRRP service set mappings provide load balancing and service abstraction for incoming traffic. For outgoing traffic that originates from installed components, including responding to incoming traffic that came through these mappings, is steered through the default gateway. At the internal firewall, the source address for the outgoing traffic is the address of the data interface on the node from which the traffic originated.
Service Set 1: Administration, Account Access (https), CAPWAP Master, Diagnostics
Table 1. Example port assignments for Service Set 1
Port Protocol Service Description
80 TCP CAPWAP CAPWAP Master
443 TCP NGINX ExtremeCloud IQ Admin, software management
1443 TCP XAPI ExtremeCloud IQ API
2083 TCP IDM IDM Auth
12222 UDP CAPWAP CAPWAP Master
Service Set 2: AP Registration/CAPWAP Load Balancing
Table 2. Example port assignments for Service Set 2
443 TCP SD-WAN SD-WAN Communicator
5825 TCP Inlets Device Communication
8090 TCP Inlets Device Communication
9090 TCP SD-WAN SD-WAN Communicator
Service Set 3: AP Registration/CAPWAP Load Balancing
Table 3. Example port assignments for Service Set 3
Service Set 4: AP Registration/CAPWAP Load Balancing
Table 4. Example port assignments for Service Set 4
443 TCP NGINX ExtremeCloud GDC access
1444 TCP API GDC API
1445 TCP License ExtremeCloud IQ License Management
Service Set 5: Login Redirection
Table 5. Example port assignments for Service Set 5
443 HTTPS (TCP) Login Extreme Platform ONE Login Rediection
