BSS Devices - Site Historical Data
This screen displays the historical data for the BSS devices identified in your selected site. You can use the Search field to filter data or devices of interest to you.
If a client's data is deleted in ExtremeCloud IQ, all configured, cached, Live, and Historical data related to that client is also deleted from ExtremeLocation Essentials.
If Reset VIQ is selected in ExtremeCloud IQ, all configured data for locations, devices, and clients is cleared from ExtremeLocation Essentials. In addition, all cached, Live, and Historical data related to that VIQ is cleared from ExtremeLocation Essentials.
  1. Select the BSS Devices menu item from the options on the left.
    The Devices screen refreshes to display the BSS devices identified for the selected site.
  2. Select a site from the Site drop-down list.
    The screen refreshes to display a list of all BSS devices identified in this site.
  3. If the Historical option is not selected, select it.
    The user interface changes to display more fields to refine the historical data.
    Historical Data Filter Fields
  4. Use the calendar control to set the Date to filter historical data. The default value for this field is one day less than the current date. You can display data for the last thirty (30) days before today.
  5. Select the Show button to display the historical BSS device data for the selected date.
  6. Review the data displayed on this screen. The following information is displayed for each identified BSS device:
    FieldDescription
    BSS This field displays the BSS device MAC address.
    SSID This field displays the SSID being broadcast by the BSS device.
    Floor Name This field displays the floor on which the BSS device was identified.
    RSSI This field displays the RSSI signal of the BSS device.
    FREQUENCY This field displays the radio signal frequency of the BSS device.
  7. Use the Search field to filter to the data of interest. Enter a search string in this field.
    Search terms are not case sensitive.
    The displayed data is automatically sorted based on the search string.
    Search Function
  8. Occasionally use button to refresh data.
    The data in this screen does not refresh automatically. The screen has to be manually refreshed to view the latest data.
  9. Use the button to download the list of devices to your local PC as a .csv (comma separated value) file.
