If a client's data is deleted in ExtremeCloud IQ, all configured, cached, Live, and Historical data related to that client is also deleted from ExtremeLocation Essentials.Note
If Reset VIQ is selected in ExtremeCloud IQ, all configured data for locations, devices, and clients is cleared from ExtremeLocation Essentials. In addition, all cached, Live, and Historical data related to that VIQ is cleared from ExtremeLocation Essentials.Field | Description |
Client MAC | This field displays the client device's MAC address. |
Device Type | This field displays the device type. This is the classification of the identified device. You can classify devices within a specific vertical. See Device Classification Settings for information on vertical device classification. |
Floor Name | This field displays the floor on which the device was identified. |
Category | This field displays the area where this device was identified or seen. A category is a user defined part of a site that logically divides the site based on the usage of the area. For example, "Warehouse", "Lobby", "Canteen" or similar. |
Site Enter Time | This field displays the time the identified device was first seen and identified on this site. |
Category Enter Time | This field displays the time the identified device was categorized as one of Visitor, Asset, or Staff. |
The Update Device Type window displays
Select the appropriate Device Type using the available options in this screen.
Once done, select the Update button to update the device's device type classification. At any time, select the Cancel button to exit without modifying the automatic device type classification.
.csv
(comma
separated value) file.
