This section explains how to obtain and install/uninstall licenses for non-Universal Hardware switches.
For the series switches, in addition to the CLI method listed below, you can use ExtremeCloud IQ to obtain licenses. For information about using ExtremeCloud IQ, go to https://www.extremenetworks.com/support/documentation/extremecloud-iq/.
You should have received by email a license voucher after your purchase of a switch. You will need the voucher ID number on this email to generate a license.The Voucher Details page displays the license key or license file at the bottom.
tftp get [ ip-address | host-name] { vr vr_name } { block-size block_size } remote-file local-file} {force-overwrite}
To copy from a USB: cp old_name new_name specifying /usr/local/ext. For example: cp /usr/local/ext/old_name /usr/local/cfg/new_name.
You can place the license file anywhere within the user-visible file system (for example: /usr/local/*).
enable license file filename
enable license {software} [key ]
To remove a license:
clear license [{software} | port-speed]
Caution
This command should be used only with the advice of a representative from Extreme Networks.
