Trial Licenses for non-Universal Hardware Switches
For non-Universal Hardware switches, you can obtain a trial license, which enables you to use
the license for 30 days, and you can downgrade trial licenses to a lower software license
level during the trial period. You can extend the time of the trial by 30 days two times (for
a total of 90 days). Most feature licenses are enabled. After you enable the trial license,
the switch behaves as if all software license levels and feature licenses are enabled. The
trial license key contains all the necessary information on the license level and the number
of days. Trial licenses can be applied only once for each software version; if you upgrade to
a different software version, you can reapply your trial license. It is not recommended to use
a trial license in production.
The Network
Timing feature license is not included in the trial license.
To enable a trial license, issue the command enable license trial.
To clear a trial license, issue the command clear license trial. A reboot is required before the clear license takes effect.
Enabling a newly obtained license requires clearing the trial license, and then rebooting
the switch.
