CVID Translation
To support CVLANs that are identified by different CVIDs on different CEPs, some switches support a feature called CVID translation, which translates the CVID received at the VMAN ingress to a different CVID for egress from the VMAN (see CVID Translation).
CVID Translation
You can use a CLI command to configure CVID translation for a single CVID or for a range of CVIDs, and you can enter multiple commands to define multiple CVIDs and ranges for translation. The commands can be applied to a single port or a list of ports, and after configuration, the configuration applied to a port is retained by that port.
CVID translation is available only on the platforms listed for this feature in the ExtremeXOS v33.6.1 Licensing Guide document.
CVID translation can reduce the number of CVIDs that can be mapped to VMANs.
