IP Device TrackingNEW!
IP Device Tracking enables the switch to send periodic ARP probes to devices learned in the nodealias table on a per-port basis. Use this feature to keep NetLogin authentication sessions active for devices that generate minimal traffic and would otherwise be disconnected by idle timeout.
When a device responds to an ARP probe, the switch resets the NetLogin inactivity timer for that session. When a device fails to respond to a configurable number of consecutive probes, the switch marks that device Inactive. IP Device Tracking operates on ARP traffic only and applies to directly connected Layer 2 devices.
IP Device Tracking must be configured independently on each LAG member port.
Device Status Values
Each nodealias entry on a port with IP Device Tracking configured is assigned one of the following status values:
ARP Probe Parameters
The following parameters control ARP probe behavior and are configurable per port:
ARP probe parameters can be configured whether IP Device Tracking is on or off, allowing parameters to be staged before the feature is enabled.
Enabling and Disabling IP Device Tracking
To enable or disable IP Device Tracking on one or more ports:
configure nodealias ports ip-device-tracking
Setting the port to off (default) stops ARP probing and sets all devices on that port to Not Tracked.
Configuring ARP Probe Parameters
To configure ARP probe parameters on one or more ports. Specify one or more parameters in any order in a single command:
configure nodealias ports ip-device-tracking arp-probe
The following example configures port 7 with a 50-second probe interval, 3-second initial delay, sender IP 20.0.0.1, and a maximum of 4 consecutive failures:
configure nodealias ports 7 ip-device-tracking arp-probe interval 50 initial-delay 3 ipaddress 20.0.0.1 max-failures 4
Displaying IP Device Tracking Status
To display the IP Device Tracking status of nodealias entries, optionally filtered by port:
show nodealias ip-device-tracking
Port   MAC Address          Alias ID  Time Last Learned    VID   Protocol  Source IP        Status
7      00:00:c0:01:0b:07          15  11-20-2025 16:59:45  10    ARP       20.0.0.15        Active
7      00:00:c0:01:0b:02          10  11-20-2025 16:59:13  10    ARP       20.0.0.10        Inactive
8      00:00:c0:01:0b:14          28  11-20-2025 17:00:14  10    ARP       20.0.0.28        Not Tracked
To display the ARP probe configuration for all ports, optionally filtered by port:
show nodealias ip-device-tracking configuration
Port    IP Device       Max     Probe  Initial  Probe
        Tracking   Failures  Interval    Delay  Sender IP
2       On                3        30       10  20.0.0.1
7       On                4        50        3  20.0.0.1
8       Off               3        60       10  0.0.0.0
Supported Platforms
All platforms.
