Use this procedure to configure Link Aggregation Group (LAG) interfaces on Universal
Compute Platform.
Make sure to configure LAG on the
switch that connects to the LAG ports. Otherwise, the LAG connection fails.
Go to .
Under L2
Ports, assign data ports to each LAG interface:
For LAG1,
select each data port that you want to add to this LAG.
For LAG2,
Select Save and
then select OK.
The LAG interface
inherits the VLAN assignments automatically from newly added port
members.
To aggregate the ICC ports,
under ICC
Interfaces, select LAG.
Complete the LAG interface
configuration for each new LAG interface:
Under Interfaces, select the new LAG interface.
Configure the interface
settings. For more information, see Create New Interface Settings.
Select Save.
