Install Engine Application
To install the engine application,
take the following steps:
Go to
From the pane for the application that you want to install, select
Install.
- If you have not yet uploaded the application docker image file, you
will be prompted to do so.
- The installation time depends on a variety of factors. Be prepared
for it to take some time.
A confirmation notice displays after the installation completes. Only
one instance is required for the cluster.
