Configure Pod Network Information
Pods are groups of containers that share networking and storage resources from the same node.
  1. Provide the following Pod Network configuration settings:
    • Pod Network IP Address
    • Pod Network CIDR
    • Service Network IP Address
    • Service Network CIDR
  2. Select Create Cluster.
    The cluster is created. If a cluster existed previously, the cluster connections are reset. Then, you must reinstall the engines for each node in the cluster.
  3. After the cluster creation process finishes, select Done.
