System Information
Go to to view system and manfacturing information. You can select either of the
following tabs:
- System Information tab
- Manufacturing Information tab
From the System Information tab, you can view the following
information about your system:
- System Up Time
- CPU Utilization
- Memory Usage
- Disk Usage
- System Temperature
- Fan Speed
- Power Supply
- Port Interface Status
Example System Information
From the Manufacturing Information tab, you can view the following
information:
- Manufacturing ID (Serial Number)
- BIOS Version
- Hardware Revision
- VF MAC base
- SMX Version
- Software Version
- Model
- CPU Type
- CPU Frequency
- Number of CPUs
- Total Memory
- MAC addresses for various system interfaces
Example Manufacturing
Information
