Add Web Proxy ServerNEW!
For enhanced data security, you can add a web proxy server. A proxy server is an additional server in a client-server deployment that provides additional data security boundaries, protecting users from malicious activity on the internet.
  1. Select the navigation menu and select Administration > System > Settings.
  2. Select the Web Proxy tab.
  3. Enter the IP Address of the proxy server along with the server Port to which you should connect.
  4. If the proxy server requires authentication, select Authentication and enter the Username and Password for an account that has access to the proxy server.
  5. Select Save.
