Before configuring the cluster, use
your Extreme Support account to download the latest revision of Universal Compute
Platform firmware from the support portal: https://extremeportal.force.com/. At this time, UCP 5.04.01 is the minimum required
revision.
Log in to the controller Admin
user interface: https://node ip:5825
Go to Administration > System > Software
Upgrade > Upload.
Upload the desired revision of
Universal Compute Platform.
A best practice is to
upgrade each of the nodes on a new cluster to the latest revision before
proceeding with the cluster set up and configuration.
Select the upgrade
From the Image Management
Tab, select the Upgrade image, and select .
Upgrade the selected
When all nodes in the cluster are upgraded
to the latest revision, proceed to IP Address Configuration.
