Deployment Requirements
The VE6120 and VE6125 are packaged in the .ova file format defined by VMware. The appliances must be deployed on a VMware ESXi host running vSphere.
VE6120 and VE6125 use separate .ova files. You cannot upgrade from VE6120 to VE6125.
VE6125 requires an enterprise VMware license to launch and run the virtual machine.
The minimum supported version of vSphere for VE6120 is 5.1 and for VE6125 is 5.5.
You only need to install the .ova file when you first install the appliance. All subsequent upgrades can be performed using the standard controller upgrade procedure to apply a .dle file to the VE6120 appliance and .rse file for the VE6125 appliance.
In addition, the appliances are configured with one Ethernet interface for administration and two data plane Ethernet interfaces for forwarding payload traffic.
If all three interfaces are used, it is recommended to connect them to separate virtual switches (vSwitches) in the host server.
Configuration Options:
Table 1. Virtual ExtremeCloud IQ Controller (VE6120 and VE6125)
Extreme ApplicationVE6120 VE6125
SmallMediumLargeXLarge
Total APs managed in Standalone mode502505002000
Additional APs supported in high-availability mode502505002000
Total managed APs per Appliance Pair 10050010004000
Total Switches managed per Appliance50/100100/200200/400200/400
Total simultaneous users in Standalone mode1,0004,0008,00016000
Additional simultaneous users in high-availability mode1,0004,0008,00016000
Total Simultaneous Users per Appliance Pair2,0008,00016,00032000
Hardware Requirements
CPU4 (4 distinct physical cores or 2 cores with hyper-threading) 6832 (physical or hyper-threading cores)
RAM (GB)8162432
Hard Disk (GB)808080512
2x1Gbps Host (Open/Secure Mbps)1,870/1,8701,870/1,8701,870/1,870-
2x10 Gbps Host (Open/Secure Mbps)10,800/5,10010,800/5,10010,800/5,100-
