Remove the Flash Drive
Follow these steps to remove the flash drive.
The Virtual Appliance can be in service when the USB flash drive is assigned to it. Within a few seconds of the USB flash drive being assigned to it, the virtual appliance will detect the flash drive and mount it for use.
  1. When you are ready to remove the USB Flash drive, click Un-Mount from the Maintenance page.
  2. Remove the drive.
  3. You can delete the USB flash drive from the VE6120's Virtual Machine Properties dialog after unmounting it from the VE6120/VE6125 appliance.
