Manage the Flash Memory
Follow these steps to manage flash memory:
  1. Log into the ExtremeCloud IQ Controller using your credentials.
  2. In the left pane, from the Administration drop-down, select System > Maintenance > External Flash option.
    Use the Mount/Unmount options to mount and unmount flash memory respectively.
    Flash Memory Maintenance Window
